Timing gear oil shield?
Old Mar 23, 2003 | 08:43 PM
airharley's Avatar
airharley
I have what looks like a timing gear oil shield in my timing gear parts bag. I can't for the life of me remember if it went on the crank snout between the spacer and crank gear, between the block and the timing gear, or fuel pump eccentric and cam gear. I would like to asemble this thing later this week but none of my books have it listed. With that being said do I really need it? I can add a picture if that helps. Thanks.
Old Mar 24, 2003 | 04:28 AM
DeenHylton's Avatar
DeenHylton
From what I remember they go between the spacer and crank gear...or in other words...they sit right up against the crank timing gear towards the front of the engine. Deen
Old Mar 24, 2003 | 08:36 AM
mchild's Avatar
mchild
Yes, Deen is correct. It goes on last thing before the timing cover and then the spacer goes on after the cover is on.
Good luck,
Mark
Old Mar 24, 2003 | 10:01 AM
airharley's Avatar
airharley
Thanks guys. I will put it together when I get home.
sessland
Jan 9, 2017 09:18 PM
Y2K X
Aug 18, 2016 10:39 PM
J1MMY
1997 - 2003 F150
Feb 3, 2016 08:20 AM
BroncoScott
Appearance & Dress-Up
Oct 31, 2003 05:19 PM
rick
May 28, 2000 12:21 AM
