HELP!!!!!!!!!!!
Old May 17, 2011 | 12:57 AM
FightingCB's Avatar
FightingCB
HELP!!!!!!!!!!!
I got a 240 - I6 that has exhaust comming out of the dip stick and oil is comming out of it as well? The valve cover at the PCV has exhaust comming out of it when it is under RPMs when I take it out like an exhaust pipe? Weird as hell but the comp reading is 182-192 I am so stumped I do not think it is a head gasket because there is no oil signature in the Radiator or not even that frothy? what can cause oil comming out of the dip stick at such an increase?
Old May 17, 2011 | 07:19 AM
Alex from GA's Avatar
Alex from GA
You don't have to have oil in the radiator for a head gasket failure. Your compression is way too high; maybe your gage is screwy. Is it overheating? You're going to have to pull the head and check things out, but you already know this.
Old May 17, 2011 | 10:09 AM
cj06's Avatar
cj06
lots of blow by rings are shot , time for new engine , try a 300 !
Old May 17, 2011 | 03:14 PM
FightingCB's Avatar
FightingCB
Thanks all I do appreciate it, I was thinking if I had to rebuild it that I should just get a 360 or 390 to shove in there.
Old May 17, 2011 | 09:13 PM
FightingCB's Avatar
FightingCB
I got a lead on a 351W I think that could plop in with the V8 mounts what do you think of that? it was not overheating at all either. Just think that it is loosing power every time I try to haul down the road. I think rather than put any more money into the six Ill just put in a V8.
