General Automotive Discussion
VOTE: Best Ford Engine?
Old May 16, 2011 | 09:15 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
We are going to play a little game.
This thread is open up to anybody and everybody. We will have different opinions and if so, please list them!
The question is.... What is the "Best Ford Engine'?
We will seperate these into groups.
In your opinion, what is the Best Ford Engine for (Please list your reasons why, if you want):
4 cylinder engine:
6 cylinder engine:
8 cylinder engine:
10 cylinder engine:
Towing (Pulling a heavy load down the road, mountain, etc):
Reliable (Easy to work on,etc):
Offroad (Bogging):
Offroad (Rock crawling):
Puller (Truck pull):
Daily Driver (could be based on Reliabilty):
Speed (Racing):
----------------------- (OPTIONAL VOTING LISTED BELOW)--------------------------
Most expensive (Build or repair):
Least expensive (Build or repair):
Worse engine Ford has ever made, period:
Slowest engine:
P.I.T.A to work on:
Loudest:
Quietest:
Can a modern diesel run without electricity:
*LIST ANY MORE YOU CAN THINK OF SO I CAN ADD THEM TO THE GROUPS ABOVE
Old May 17, 2011 | 11:10 AM
im2tall33's Avatar
im2tall33
the best all around ford motor in my opinion is the 300-6!! hands down
Old May 17, 2011 | 11:24 AM
Grubbworm's Avatar
Grubbworm
I have to second that. But, I might be biased, since I own one.
Old May 17, 2011 | 11:37 AM
im2tall33's Avatar
im2tall33
i have owned 4 of them we also have the origninal 300 in my dads 81 bronco with well over 200k on it never rebuilt!
Old May 17, 2011 | 12:28 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The best gasoline engine ever is the 300 I-6, so it stands to reason it's the best Ford engine. It beats out most other I-6 engines due to the gear driven cam, rather than a chain drive.
As for most expensive to rebuild, Mazda Rotary. $4-6K is not uncommon for an investment in rebuilding. May only have 3 moving parts, but they're expensive critters.
Old May 17, 2011 | 06:43 PM
Greywolf's Avatar
Greywolf
I submit for your inspection that from a MILITARY point of view LONG LASTING is a huge consideration....
Gas engines may have a disadvantage there, because diesels just keep on going (if they are older generation)
~Strip off everything else from it, and what gets you home is all that matters...
Q: Can a modern diesel engine run without electricity?
Old May 18, 2011 | 02:19 AM
Cruiseomatic's Avatar
Cruiseomatic
300-6. Period. Will pull anything and still get you home on just 2-3 cylinders.
Old May 18, 2011 | 11:12 AM
Old93junk's Avatar
Old93junk
Worst:
2.3 HSC 4 cyl. engine they put in early Tempo/Topaz and early Taurus/Sable.......Buzzy, noisy, POS....... Transmissions lasted longer than the motors and that ain't saying much.
Old May 18, 2011 | 11:20 AM
im2tall33's Avatar
im2tall33
i agree dave..although i seemed to have a decent 2.3 in my 90 notchback i had...but the 2.3 i had in my old 79 mustang II was another story!
Old May 18, 2011 | 11:28 AM
Old93junk's Avatar
Old93junk
That's an entire different and damn good 2.3! the 2.3 HSC was a stand alone design and not related to the excellent Lima 2.3 in Mustangs, Rangers, Pinto's, Capri, T-bird turbo-coupes.
Old May 18, 2011 | 11:33 AM
im2tall33's Avatar
im2tall33
i love the turbo 2.3 those things are quick
Old May 18, 2011 | 11:50 AM
Rogue_Wulff
The 2.0/2.3/2.5L OHC "Lima" engines were never known for having a lot of power, but they made up for it by having long lifespans. Their only weak point is the belt driven cam/aux shaft. At least it could pop a timing belt without doing major damage to the valvetrain, just slap another belt on and go.
Amazingly, my 2.3L had the timing belt WAY off, and it still managed to run, just not very well.
The 240/300 I6, and the 2.0/2.3/2.5L OHC I4 both fall into the same heading. They are like a sore peter, unbeatable......
Old May 18, 2011 | 11:54 AM
Old93junk's Avatar
Old93junk
2.3 Lima 4s are like a stock 460.........not too impressive on power at first glance, but my, oh my.....The untapped potential that's there with a little work.
I have seen some 2.3s that were a little "warmed over" that could put most V-6s in the weeds without breaking a sweat.
Old May 18, 2011 | 11:58 AM
Rogue_Wulff
Yes, Ford left a lot of untapped potential in both.
Funny thing about the 300 and 2.3L. Both were typically backed by rather tall gears, compared to most other brand engines of the same class. Yet somehow, they still managed to outwork their competitors......... While getting better MPG.
Old May 18, 2011 | 11:59 AM
jimandmandy's Avatar
jimandmandy
Modern? Last 50 years (OHV era) or all time?
I'm going with all time.
Towing: any modern diesel (not counting reliability)
Worst: Lincoln V-12
Slowest: Model T
