gearbox advice
Old May 16, 2011 | 03:36 PM
cooprz's Avatar
cooprz
gearbox advice
hi all,
i have purchased a 95 f-150 engine & gearbox for my 56,it`s a 351 windsor with a e4aod.the problem is i can`t lower the engine anymore & the cab floor needs to be cut.was wondering if i should change out the gearbox for maybe a 4l65e as the e4aod is such a large box.have really only 2 concerns, the sheer size of it & how much power it will take to run it.
any advice or input welcome.
cheer`s craig.
Old May 16, 2011 | 03:40 PM
85e150's Avatar
85e150
Yup, the E4OD is a monster.
BUT, they are not cheap, and if it's a good trans, you should be able to sell it for a good chunk of change.
Serving suggestion would be a beefed AOD. Not much bigger than a C4 and it has OD.
Will recheck and add more info if you are interested in going that way. Gotta hit the trail....
Old May 17, 2011 | 03:40 AM
cooprz's Avatar
cooprz
gearbox advice
thanks 85e150six4mtod my gearbox is a very low milage unit, will try & sell it & rethink what to run in it`s place.think a later model gm unit with an adapter plate may work,as this will negate the need for a tv cable.
thanks for taking the time to reply.
cheer` craig
Old May 17, 2011 | 01:36 PM
85e150's Avatar
85e150
Some if not all 700Rs need a TV cable also:
http://www.tciauto.com/Instructions/...ble_adjust.pdf
JMO, but the hassle and expense ($443.95 at PATCO) of an adaptor, plus having to deal with the GM TV cable, speedo cable, mounts etc, would be more work and hassle than dealing with an AOD.
AOD Transmission from PATC, AOD Transmissions
