Clutch Line Question
Old May 16, 2011 | 10:53 AM
JRS2's Avatar
JRS2
Looking for opinions regarding materials used for the slave cylinder. Where the fitting on the line going into the slave cylinder - OE part was aluminum - corrosion defitely was going on there. I need to replace, finding that one after market company uses a plastic line with the oring as usual for sealing, a couple others use a steel or brass type line. Just wondered what you guys have found that might have used these - best recommended ?? If plastic will not rust or corrode - but will it be durable enough ? Thks
