Hi guys we went camping this past weekend. I was running my AC unit during the day then at night I shut it off and just ran my fan. The next morning was pretty cold so I shut off the fan and noticed my compressor was still running. With the thermostat off and no fan on. The only way I could shut down my compressor was to shut off the breaker any ideas?
ok thanks now I forgot to mention if you adjust the thermostat to where the fan comes on it will, does that make any difference? Like if its 75 in camper and you put thermostat on 71 the fan will come on by itself but no matter what you do the compressor keeps running.
we used our brand new camper last weekend and had a similar expierence. We turned on the furnace and set the tstat to furnace mode. but even when the furnace turned on and was blowing heat from the floor register, so was the A/C unit blowing cold air out of the ceiling vents. I didnt have time to look at it so I just shut the A/C breaker off?????
Well got it fixed this weekend was a bad controller in the unit itself right under or over the air filter. Big silver box with lots and lots of wires wasnt to bad thought to replace and works great now :-) they told me a relay was stuck and only way to fix it was the whole box.
