OT-mig welder question
Old May 15, 2011 | 11:38 PM
tardster's Avatar
tardster
I have a lincoln 120-140 whichever it is, it has the gas hook up and works really good. I picked mine up at Lowes for 450-500, its the best money I've spent out of all my tools...
Old May 16, 2011 | 08:11 AM
AXracer's Avatar
AXracer
Originally Posted by dongc1
X2 on the Hobart 140 from Tractor Supply. I love mine. The main thing I have found out about on these 120V machines is the supply circuit must be capable of 30 amps. I put in an outlet with larger wire and larger circuit breaker and it made a huge difference in how it welds. I got an extension cord that they sell for hooking up a Motor home. It's real heavy wire. I can use the welder all over the shop with it.
My Hobart 140 works just fine on a 20A (12ga) circuit. If it needed a 30A circuit they would have put a 30A plug and cord on it.
Old May 16, 2011 | 11:27 AM
raerjim's Avatar
raerjim
Well...now i gotta scratch my head and figure out what to do...
thanks![/QUOTE]
Contact the MFG.
Old May 16, 2011 | 11:53 AM
AXracer's Avatar
AXracer
The Mfg says that's the way it's supposed to work. I guess that's how they can sell it so cheap, eliminate the expensive high amp relays etc.
Old May 16, 2011 | 11:57 AM
sdetweil's Avatar
sdetweil
thanks!
I have a range of stuff, collected over time (all since acquiring the green truck pile of parts in 2000)..
I started with a Harbor Freight 120v 90amp mig gas + flux cause at $199 in 2001 it was a cheap start.. and good for bigger metal, not so good for body, 4 heat settings..
that worked until 4 yrs ago.. doesn't trigger anymore. still have to look at it.
I also bought a HF mini TIG inverter system.. harder to use than expected, but I did use it to do some of the headers.
along the way, I got a bonus at work and bought a Miller 175 240v MIG,
man what joy to use.. variable power SO much better than the HF.. wow.
at the same time I bought a used Miller 180 syncrowave Tig machine, pedal control.. SO much easier.. still learning
and then we moved to the country, and I needed to weld on my gate, but don't have 220/240 power out there.. so I bought a Lincoln 140 120v unit of CL cheap at $300 new in the box. it also has GAS support, but haven't hooked it up yet. only really used for welding at the gate.
My son works in a metal door factory up in Dallas, they have a ton of equipment.. last summer they were getting rid of some non-working stuff, so I picked up a millermatic 200 mig machine, 200 amp... heavier than the 180 tig machine. no torch. found a used torch on ebay for $30, and the problem turn out to be a burned wire inside. must have a 20lb spool of 035 wire too. (least a foot across and 4 inches thick)
we used it to weld the base plates for the metal building we put together in January.
I use the 175 the most by far.
so, variable speed, variable heat, support for shielding Gas, highest power u can afford, and think about where u might want to use it..
I would have to buy a generator for anything other than at my gate, and using 220 makes it hard to take over to a buddies house for that quick fix you can do...
Sam
Old May 17, 2011 | 12:00 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Sam you must have alot more storage space than me! as AXracer said, I found out that it in fact is supposed to have weld amperage even without pulling the trigger..its better than nothing but it would be nice to upgrade.
and oh btw SAM..! I was looking at some pic you posted, it showed your equalizer bar for the engine hoist. I have had one like yours forever and never really knew what it was...I know stupid huh? well it was left behind a storage unit leaning against a dumpster, of course I had to pick it up..
I've had it 10 plus years laying in the corner, saw your picture and MAN is it ever helpful! Thanks Sam! It's another one of those"i will get to it eventually" stories...
Old May 17, 2011 | 05:55 AM
sdetweil's Avatar
sdetweil
you know the saying about space, your junk will expand to fill it regardless of size! but I have 2 full truck chassis inside, plus another cab. and a couple workbenches, and the pallet rack at one end, and a smaller section at the other end.
yeh, the engine leveler is amazingly handy. you can tilt the engine/tranny combo, then straighten it out as needed. and balance it flat. I think I bought it at HF for $10.
Sam
Old May 17, 2011 | 03:16 PM
Jeff and Nicolle
oh ok so i have been carrying this around for ten plus years and all it cost new is ten bucks...wow...oh well, it is what it is! still i credit your photo for allowing me to see its purpose !
Old May 17, 2011 | 04:02 PM
sdetweil's Avatar
sdetweil
today harbor freight lists this for 29.99
3/4 Ton Capacity Heavy Duty Load Leveler
sam
cosmaar1
Oct 17, 2014 11:41 AM
Drewski 2
Aug 15, 2014 07:42 PM
smallello
16
Dec 20, 2013 07:08 PM
inliner
Sep 2, 2004 04:49 AM
astrotaz
Garage & Workshop
24
Mar 21, 2004 06:26 PM
