Sponsored by: Real Truck
Tire balancing issue
Old May 15, 2011 | 07:00 AM
high ho silver's Avatar
high ho silver
Question Tire balancing issue
I have BFG All Terrains 315/75/16. Been on the truck for several years now. Never had any problems with balance. Took in for rotate and balance a few weeks ago and noticed vibration from the rear during the trip home. Went back and had them rebalance. The tech told me the rear two were both out 2 ounces. Odd since they had just balanced them. After balance number 2, went back and had them do another balance. They drove the truck after balance 3 and said all was fine. Well I still have a vibration. I am going back again to have them put the rear two on the machine with the weights still on them to see if they are out of balance again. The tire store is very reputable and I have used them for years. Could there be some other tire issue causing them to continue to be out of balance?
Old May 24, 2011 | 02:57 PM
sidrush's Avatar
sidrush
we have had that alot when changing tires front to rear and the tires are 100% ballanced. we have had to put them back on the front and all is fine unless you took in in because of a vibration. then you need to look for a belt or buldge problem.
Old May 24, 2011 | 07:41 PM
a57chevy43's Avatar
a57chevy43
Maybe water or fix a flat in tire
