Fuel Air Mixture
Old Dec 14, 2002 | 03:58 PM
froman23's Avatar
froman23
Fuel Air Mixture
I have a 93 f150 302 with an AODE. My truck has been pinging alot at low rpms. Need to know what is the cause of this. It has about 118,000 on the moter. Does it need to be rebuilt or just a good tune up and if there is anything that i can do to stop it from pinging. I am farly good with moters so any thing that is not to hard i can do.
Thanks all
Rudy
Old Dec 14, 2002 | 05:27 PM
PATS2002's Avatar
PATS2002
Fuel Air Mixture
I was reading the Haynes Manual for something else and I came upon something about the knock sensor. My truck has been pinging too when I get on it. I thought It was crappy oxygenated fuel so I have been using mid grade fuel. The manual goes into the whole explanation about how to test and explains what it does(adjusts the timing). This could be a place to start.
Old Dec 14, 2002 | 05:43 PM
steve83's Avatar
steve83
Fuel Air Mixture
Pull the code & see what the computer says is the problem. You might need to replace the HEGO or FPR.
Old Dec 14, 2002 | 07:10 PM
Racerguy's Avatar
Racerguy
Fuel Air Mixture
Have you checked the timing? It should be set at 10 degrees with the SPOUT disconnected. Have you done anything to it recently? Plug wires? If they arent routed correctly you can get pinging due to crossfiring.
Old Dec 15, 2002 | 07:10 PM
froman23's Avatar
froman23
Fuel Air Mixture
I have not checked any of this. How hard is it to do all of these things and what type of tools do i need to do the timing. That is what i thought it was but i dont want to mess anything up in my moter.
Thanks for the help
Rudy
Old Dec 15, 2002 | 07:11 PM
froman23's Avatar
froman23
Fuel Air Mixture
One more thing, i also put headers on it some time back.
Thanks Rudy
Old Dec 16, 2002 | 12:17 AM
steve83's Avatar
steve83
Fuel Air Mixture
Pull the codes http://www.broncodata.com/tech/codes.htm
Old Dec 16, 2002 | 12:22 AM
steve83's Avatar
steve83
Fuel Air Mixture
