dash air flow
Old May 14, 2011 | 07:19 AM
krija's Avatar
krija
dash air flow
getting NO air flow through dash vents.
solutions?
thanx
Old May 14, 2011 | 07:26 AM
ccarrier's Avatar
ccarrier
fan working?
blendoors working?
Old May 14, 2011 | 07:32 AM
Talyn's Avatar
Talyn
Blenders working too?
Might need to make a margarita. ...
just sayin.
Talyn's Avatar
Talyn
Check the vacuum lines on the back side of the climate controls.
I've had to lube the block up again cause it started to dry out and not seal any more.
Old May 14, 2011 | 11:13 AM
krija's Avatar
krija
fan good,,
need to check op of blend doors
thanx
Old May 14, 2011 | 11:17 AM
Ken_C's Avatar
Ken_C
yep. when crap falls down the vents in the top of the dash, it tends to jam stuff up.
Old May 14, 2011 | 11:32 AM
krija's Avatar
krija
could you suggest good online site or manual showing diagrams and/or replacement steps?
Old May 14, 2011 | 02:45 PM
Cuda_jim's Avatar
Cuda_jim
If it's stuck on defrost you have a vacuum leak or the pump is not working. The brakes will fell rock hard too though.
Here's a Factory Shop Manual online
1996 Bronco/F-Series Workshop Manual
Old Jun 24, 2011 | 03:32 AM
krija's Avatar
krija
Thanx cuda
