Hot engine????
Old May 13, 2011 | 10:46 PM
Howard61's Avatar
Howard61
Hot engine????
Hey I was just wondering if someone could help me out w a question about my engine? I just purchased a 2011 250 super duty w the 6.7 diesel two days ago and tonight I ran to the store then came straight home. Two hours later I walked out to get something out of it and as I walked by the front of the truck I could feel a lot of heat. I opened the hood and EVERYTHING under the hood was really hot??? Literally every hose and every component was extremely hot. I left the hood open and started the truck. After I ran the truck for about 5 minutes I turned it off and everything had cooled off??? My oil temp and trans temp both were around 154 degrees, is this normal? This is the first diesel I've ever owned so I was just wondering if this was normal or should I be concerned???
Old May 13, 2011 | 10:52 PM
maistroyoda's Avatar
maistroyoda
That sounds strange. You would think that after two hours it would have cooled off but I'm no expert. Give it some time and the veterans will advise.
Old May 13, 2011 | 11:18 PM
Howard61's Avatar
Howard61
That was my thought as well. I figured two hours was plenty of time to cool off!
Old May 14, 2011 | 07:25 AM
dschuffert's Avatar
dschuffert
It all depends. What was the outside temperature where the truck was sitting? Two hours does seem like a long time, but there are many other factors that need to be considered, such as outside temperature, temperature of the coolant and oil when you shut it down, how windy or not it was where the truck was sitting, etc.
Old May 14, 2011 | 10:30 AM
Howard61's Avatar
Howard61
Thanks guys for responding. I took the truck in this morning to the dealership to have it checked just in case. They told me it was normal for the engine to be hot even after a few hours of sitting. The temperature yesterday at the time this happened was around 65 degrees, so not to warm. They also told me that the oil temp should range over 200 normally and the trans fluid around 190 which is where both have been all day today. So that definately made me feel better. Ive never owned a diesel so it kind of took me by suprise last night, kinda scared me at first, but everything looks to be normal. I have to say i LOVE this truck, by far the best truck ive ever owned and im on number 30 with this one. Thanks again for your responses
Old May 14, 2011 | 11:12 AM
jstange2's Avatar
jstange2
Mine stays warm for quite a while too.
Old May 15, 2011 | 05:54 AM
ruschejj's Avatar
ruschejj
With modern diesel engines there is a very large BTU output. All diesels make a reasonable amount of heat but not as much as a gasser while under load, but there is a lot of mass to it which holds heat and slowly lets it go to the atmosphere.
Old May 15, 2011 | 06:44 AM
senix's Avatar
senix
When I have towed cross country in 105F+ temps..it gets so hot under there I don't even shut it off till the end of the day.
I pop the hood during fuel stops but leave it running.
I am sure the 6.7 is just the same.
Old May 15, 2011 | 10:47 AM
sledhead_24_7's Avatar
sledhead_24_7
Originally Posted by Howard61
Thanks guys for responding. I took the truck in this morning to the dealership to have it checked just in case. They told me it was normal for the engine to be hot even after a few hours of sitting. The temperature yesterday at the time this happened was around 65 degrees, so not to warm. They also told me that the oil temp should range over 200 normally and the trans fluid around 190 which is where both have been all day today. So that definitely made me feel better. Ive never owned a diesel so it kind of took me by surprise last night, kinda scared me at first, but everything looks to be normal. I have to say i LOVE this truck, by far the best truck ive ever owned and im on number 30 with this one. Thanks again for your responses
Mine normally runs around 195-200 on the oil temp empty, trans is about 190-192 empty as well. But as others have said there is a lot of mass under the hood to hold heat and it takes awhile for it to dissipate.
Old May 15, 2011 | 01:51 PM
bartlanz's Avatar
bartlanz
I cant speak to these trucks, but I know on most of my other trucks, the engine keeps warm for a long time, even in the winter. I have always felt it was a benifit of the engines being larger. Means that I go to a resteraunt and come out after and the engine is still warm
