1980 tailights?
Old May 13, 2011 | 07:54 PM
vinny80's Avatar
vinny80
1980 tailights?
well, my tailights dont work..maybe? when i start the truck up and pull out the switch, healights come on, but the tailights dont. brake lights work and turn signals work, but tailights dont..weird things is, after maybe 15 minutes, they will come on? never heard of warming up your tailights aha =p sometimes they wont work at all. is this my headlight switch? or faulty wiring..
Old May 13, 2011 | 09:01 PM
ctubutis's Avatar
ctubutis
I'm gonna guess bad grounds.
Remove the tail light assemblies (4 screws) and clean the ground connections to the sheet metal.
You should also make sure the bulb sockets are in good shape.
All the marker lights are fed by a single, brown-wire circuit.
Old May 13, 2011 | 09:07 PM
Franklin2's Avatar
Franklin2
The front markers and fender markers don't work either correct?
Old May 17, 2011 | 06:28 AM
vinny80's Avatar
vinny80
all other lights work, and the rear bulbs have been replaced with the 1157 bulb..
Old May 17, 2011 | 12:18 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Grab a test light, and see if power is getting to the bulbs. If it is, start checking the grounds. It not, start tracing the wires back towards the front while probing for power. At some point, you should find where the break is.
