U-joints
Old May 13, 2011 | 02:02 PM
KO1960's Avatar
KO1960
U-joints
I am replacing the 3 u-joints and driveshaft bearing on my '65 F250. The driveshaft seems to be pressed on to a splined shaft, but the new one, purchased from LMC, is smooth on the inside with a loose metal collar. Does the bearing need to pressed off, or am I not persuading it properly?
Kurt
Old May 13, 2011 | 07:11 PM
Jetcopterpilot's Avatar
Jetcopterpilot
The carrier bearing needs to be pressed off and then the new one can be pressed on. At least that is how mine is set up! My Local Napa did it for me just for buying the Carrier bearing, and U-joints, it was cheap and easy. Mine had a fling ring for the grease, in front of the carrier bearing, make sure they get it tight, or it will ring something fierce. The first time mine sounds like a school bell, but now it is fine...all is quiet!
Old May 13, 2011 | 07:37 PM
KO1960's Avatar
KO1960
There is a large collar behind the bearing. Does that come off with the bearing? I also have a small collar on the shaft side. Is that the "fling ring" that you are referring to?
Old May 13, 2011 | 10:04 PM
Jetcopterpilot
The fling ring is your large collar that faces the transmission it is to keep crud out of the bearing area!
Old May 14, 2011 | 12:33 AM
KO1960's Avatar
KO1960
Thanks Jet. I guess there are some things I just can't do myself.
Old May 14, 2011 | 12:57 AM
Jetcopterpilot
Well if you had a press you could!
