dana 60 conversion
Old May 12, 2011 | 11:47 PM
fordtorque's Avatar
fordtorque
dana 60 conversion
looking at doing a dana 60 conversion in my 1979 f250 with a dana 44 3/4 leaf springs.
the dana 60 i have is from a 1993 f350 ball joints.
so can someone throughly explain to me what all needs to be done to put the dana 60 into the 1979 f250.
please do not flame on me or put pointless comments.i come onto this forum for help and support from all the experts.
thanks everyone.
Old May 13, 2011 | 12:21 AM
montana_highboy's Avatar
montana_highboy
You have quite the task in front of you... https://www.ford-trucks.com/forums/7...0-highboy.html
Old May 13, 2011 | 04:44 AM
Xauterus's Avatar
Xauterus
Would you be better selling the dana 60 and buying a 1979 f350 dana 60 which will bolt in?
Corey
Old May 13, 2011 | 06:02 AM
shookdaddy's Avatar
shookdaddy
ok man this is not as much of a job as u think u will need to take all of ur measurements n have the spring perches on ur new rear spaced out to fit ur leaf springs i always reccomend replacing the u-bolts roll it under ur trk n bolt it in (u will need the steering bars & brakes n calipers) that go w the new rear u will need to have ur pitman arm milled out to fit the new draglink u should run a 4in drop pitman arm because u will need to reclock ur pitman arm to where it points to the front instead of out the side of ur trk the biggest part of this is if ur trk is lifted because u will need to ck for clearance for the pitman arm then it just hookin up brake lines u will def need to get everything lined up now ive done one of these but its been a few years but im sure that someone will let u know if i missed something but its no different than straight axeling a 80-97 n we do atleast 5 a year if it goes well u should have it done in a day we do the 80-97s in around 6hrs so just take ur time n double ck everthing
Old May 13, 2011 | 09:30 AM
PA74F250's Avatar
PA74F250
My advice to you is sell the D60 you have and get the right one from a '79. The one you have is still worth money why not sell it and get the right one. It would be a whole lot less work and will fit better. I think the overall width of the one you have is wider and probably wont look quite right when its under it.
Jake Violando
Dec 11, 2015 06:45 AM
Jakkpine
23
Aug 21, 2014 11:17 PM
thewestie
43
Jul 21, 2014 07:50 AM
montrealford
13
Nov 21, 2013 06:48 AM
Exoptable
Dec 31, 2009 01:38 AM
