Got a call from a guy i buy alot of parts from, and he said he has a 534ci heavy duty truck engine that would fit in my 76 half ton. is he off his rocker?
1958–1981 Super Duty truck engine — big-block (401/477/534)
The 534 produced 277 hp at 3400 rpm and 490 lb·ft of torque at 1800-2300 rpm. A marine version, commonly referred to as the "Seamaster" was also available starting in the late 1950s. The Seamaster was available with twin turbochargers, and weighed over 1,300 pounds installed.
Introduction
The 534 was introduced in 1958 as a viable alternative to the new turbo-diesels that were just beginning to hit the large truck and towing market.
Engine Family
The 534 was part of Ford's Super-Duty engine family, which shared almost no common components with any other.
Basic Architecture
This monster-block does bear a certain family resemblance to the Y-Series and FE big-blocks that were introduced with it, but everything on the Super-Duty block is at least 10 percent bigger than on either of those.
Power and Weight
Road-bound versions of the 534 were rated at 234 horsepower at 3,400 RPM, and 490 foot/pounds of torque from 1,800-2,300 RPM. The engine was surely a porker, at well over 1,000 pounds.
The Seamaster
The Seamaster Marine version of the 534 came factory-equipped with a pair of turbochargers and inter-coolers, and made over 400 horsepower and 900 foot/pounds of torque.
I haven't looked close at bell housing patterns, clutch options, flywheels, mounts, etc. It'ld be like putting your two best buddies under the hood on top of that 390 and shutting the hood. Lot of weight.
Road-bound versions of the 534 were rated at 234 horsepower at 3,400 RPM, and 490 foot/pounds of torque from 1,800-2,300 RPM. The engine was surely a porker, at well over 1,000 pounds. ""
The guy needs to be placed back on his rocker. The 534 has no business being in your engine compartment. Would it be sweet? Yes. Just don't do it. This engine does herculean work, and LAUGHS at death, it also does it in geological time frames as it gets drunk on your gasoline.
