1978 - 1996 Big Bronco
Ford paint problem??
Old Mar 23, 2003 | 10:37 AM
Thibor91XLT's Avatar
Thibor91XLT
Question Ford paint problem??
Was 1991 a bad year for green paint or what? My Bronco looks like it has leprosy all over the front of the hood! If I buff out the spots and remove the old, flaking paint, should I try to match the color or just repaint the whole truck? The rest of the truck isn't bad and the paint looks fine except up front. Any input would be appreciated!!
Old Mar 23, 2003 | 10:56 AM
Spudco's Avatar
Spudco
Don't feel too bad, my 91 F150 has a bad paint peeling problem on the hood too!
Mine is the silver which is known to peel badly. Like yours, my whole truck looks great, except for the hood. The top layer of the paint just peels and blisters off. The primer under it is bulletproof.
I'll have to get her painted soon though, there isn't much paint left!
Spudco
Old Mar 23, 2003 | 11:26 AM
craterjoe's Avatar
craterjoe
I had an 87 f-150 that had the same paint peeling problem on the rear of the bed sides. it looked like an appeloosa horse
somewhere caughtup in the cobwebs of the back of my brain I seem to remeber a recall or tsb regarding paint adhesion issues with the Ford truck line. at any rate I see alot of blue ovals with primer showing.
Old Mar 23, 2003 | 11:43 AM
steve83's Avatar
steve83
Chris
If your truck is still pretty otherwise, then you should probably get a pro to either match the body paint, or reshoot the whole thing. If you go all the way, don't feel like you HAVE to stick with OE color - get what you want!
If it's a work/play truck, just strip it & touch it up yourself. You'll be doing it again next time you go off-roading or bump into something, so no biggee.
Old Mar 23, 2003 | 03:33 PM
saanders's Avatar
saanders
The primer is the problem, not the paint. To completely cure the problem you have to remove the primer, which means you take the truck down to bare metal and redo the primer coat. Not a cheap process.
Ford repainted by '90 Bronco under warranty in 1994 because of this problem.
Old Mar 23, 2003 | 05:31 PM
AlM's Avatar
AlM
http://www.hvaa.com/excerpt.htm
Old Mar 24, 2003 | 12:51 AM
mrwizard's Avatar
mrwizard
Yep, the primer was so smooth that paint wouldn't adhere to it very well. My Dad had to have his '88 Gray/Silver Bronco repainted because of this.
nonrev321
Jun 4, 2016 08:04 PM
1986-460
Appearance & Dress-Up
Sep 9, 2015 07:31 PM
aclaybor
25
Feb 14, 2014 11:43 AM
CPT_Diesel
Jun 8, 2008 06:22 PM
