levelling kit
Old May 12, 2011 | 07:31 PM
goosehunta's Avatar
goosehunta
levelling kit
I have a 06 F350 SRW FX4 and was looking for a leveling kit to raise the front end up a hair. when i looked under the fender it looks like there is already a spacer on top of the spring. it has a ford name on it. is this fro the factory or put on later. does the spacer you buy to do the lift go on the top or the bottom of the coil spring?
thanks
Old May 12, 2011 | 08:05 PM
crivaro's Avatar
crivaro
The spacer you are talking about is the stock spacer. There are a few different ways to level it out. Depends how much money you want to spend. There is a 2.5 inch spacer that goes on top of the coils that replaces the factory spacer you are talking about. DayStar makes them and they are around 100 bucks. Then there are replacement coils that are longer and level it off. Superlift or Skyjacker makes them (around $250-275). Finally, there are metal leveling spacers that go under the lower coil seat (under the coil spring). Rough Country and a few others make these type kits. Rough Country's site says $100. It's not a difficult job and looks a lot better leveled!
Old May 12, 2011 | 08:22 PM
goosehunta's Avatar
goosehunta
sounds good your answer is what i was looking for. think i will go with the daystar spacer. i agree with you they look alot better. im also looking at getting new wheels and been trying to figure out what back spacing i will need. the leveling kit should get the fenders up and out of the way for the 35s.
thanks again
Old May 12, 2011 | 08:30 PM
crivaro's Avatar
crivaro
Yeah, I ran 18" moto metal 951s and 35x12.50s. Just might have to do a minor trim to the front bumper and she'll be good to go!.. Again, no worries, its an easy project. Unbolt the shocks, sway bar links and brake line bracket and the whole front end lowers. Swap out the spacers and she's ready to roll! Takes bout an hour.
Old May 12, 2011 | 09:21 PM
goosehunta's Avatar
goosehunta
i also read on daystars website that there spacers require longer front shocks????
are you useing the stock lenghts or longer
Old May 12, 2011 | 10:16 PM
rdunagan's Avatar
rdunagan
i bought mine off of ebay for 79 bucks. it wasnt a brand name but it is built sturdy! i didnt have to get longer shocks but chose to. i think either 4 wheel parts or xdp has a 4 shock deal for 100 bucks. get a 0 offset. it will make them stick out right to the fender. not over nor inside they are perfect
Old May 13, 2011 | 12:12 AM
Ian123's Avatar
Ian123
I started a thread like this over in the super duty section. I will be ordering a 2.5" spacer kit tomorrow and installing it by next weekend so I'll let you know how it goes. I'm not going with the longer shocks I think I'll be fine. Some people say you need an adjustable track bar or track bar drop bracket, but I'm not doing that either lol
Old May 13, 2011 | 04:36 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I took out my spacers in the rear....perfectly level...look in my gallery
and my 1989 Swift DB4...under my user name..you will see I pull a big trailer and the truck fits in the garage
Old May 13, 2011 | 07:09 PM
goosehunta's Avatar
goosehunta
rdunagan
i have already ordered the wheels this morning and ordered with a 4.5 offset. wish i would have read your post before i ordered them. think i will just deal with it and see how it looks when i get them.
i will be looking at more spacers and i think i need new shocks anyway. just aint sure what shocks i want to go with. i will be looking around to see whats out there. i dont do any real real heavy towing so i shouldnt need the adjustable shocks. but i think i may go with the rancho shocks.
Old May 14, 2011 | 04:49 PM
crivaro's Avatar
crivaro
I didnt put longer shocks on there when I leveled it. Kept the stock Rancho shocks on there. It wasn't leveled very long before I went higher though. 6 inch lift, then 8.5 Probably wouldn't be a bad idea to get some longer shocks so you don't have to worry about anything.
Old May 14, 2011 | 04:54 PM
crivaro's Avatar
crivaro
My lift is a Pro Comp lift so I went with their shocks too. No complaints, and they aren't too pricey. Look at 4wheel parts or National Tire and Wheel. Wanna say they were like $35-$40 a piece.
Old May 14, 2011 | 07:39 PM
ZeroTucker's Avatar
ZeroTucker
Originally Posted by goosehunta
rdunagan
0 offset is the same thing as 4.5" backspacing if you got 9" wheels. Your wheels will fit fine.
Old May 14, 2011 | 07:54 PM
goosehunta's Avatar
goosehunta
the wheels i ordered are 20x10 with the 4.5 offset. how much do you think they will stick out
Old May 14, 2011 | 08:11 PM
ZeroTucker's Avatar
ZeroTucker
I'm sure you mean 4.5" backspace. Backspace and offset are two different things. For example, a 10" wheel with 0 offset has about 5" backspace; a 9" wheel with 0 offset has about 4.5" backspace.
A 10" wheel with 4.5" backspace means that you have 5.5" of wheel going the other way. They will probably stick out close to one inch, not too big of a deal. Just make sure that you have clearance with the lower valance when turning.
Old May 14, 2011 | 08:23 PM
goosehunta's Avatar
goosehunta
you are right. i just looked at the wheels again online and it is backspace. i hope it clears it. i think it should. it has the stock 20" wheels on it running the stock tire size which i think is equal to a 34 inch tire. if my memory is correct. looking at the wheel and tire on the truck i think i should not have a problem with the new ones wraped with 35" tires. thats also why i was looking at a leveling kit
here is a link to the wheels i ordered if you want to take a look at them.
Dale Earnhardt Jr Series Wheels Part W/P10912170 - Dale Earnhardt Jr. DJ1091 Cannon Wheel - Gloss Black With Machined Face
