Hub Questions
Old May 12, 2011 | 05:43 PM
FordF350Guy's Avatar
FordF350Guy
Hub Questions
I have a 1981 f350 will locking hubs form the same year f250 fit?
Old May 12, 2011 | 05:54 PM
FordF350Guy
or does anyone know were to get good hubs for my truck for less than $150
Old May 12, 2011 | 07:59 PM
Diesel_Brad's Avatar
Diesel_Brad
Your 81 F350 "SHOULD" have a TTB Dana 50.
If it does, then you can use hubs from another Dana 50 TTB(f250 or early f350) or a Dana 60 solid axle(ford{f350} chevy or dodge)
be carefull alot of the earlier f250s used dana 44s and those hubs will not work
Old May 13, 2011 | 11:27 AM
FordF350Guy
ok thats diesel brad thats what i thought
Old Jun 22, 2011 | 07:07 AM
FordF350Guy
so I went to NAPA and ordered parts and there too small
Old Jun 22, 2011 | 10:13 AM
Rogue_Wulff's Avatar
Rogue_Wulff
D44 locking hubs are 3.25" diameter, and D50/D60 locking hubs are 4" diameter.
I always tell people to ID the front axle in a 80+ ford, measure hubs. 3.25" = D44. 4" = look underneath to see if it bends in the middle, Yes = D50, no = D60. Pretty accurate system, so long as it hasn't had a bunch of modding/swapping done over the years......
Old Jun 22, 2011 | 12:38 PM
Franklin2's Avatar
Franklin2
Autozone has the hubs for $159.00. #449ss. But they will have to order them, they don't keep them in stock.
Old Nov 11, 2011 | 01:11 PM
kraylake's Avatar
kraylake
i had the same problem, hubs from an 83 f250 wouldnt fit my 80 f350. i bot Mile Marker hubs from Summit Racing Mile Marker 449SS - Mile Marker Supreme Locking Hubs - Overview - SummitRacing.com $89..great deal!
Old Nov 12, 2011 | 05:51 AM
Diesel_Brad
That is because most likely you had a Dana 44 in your F250 and you have a D50 in your F350
Old Nov 28, 2011 | 04:20 PM
FordF350Guy
i want to get a lift for the truck and i want to loosen up the ride a little. will a lift for a f250 same year fit on the same?
Old Nov 28, 2011 | 07:58 PM
Franklin2's Avatar
Franklin2
You had better stay stock if you want to keep your ride. A lift will make it stiffer, and larger tires and wheels makes it ride rougher and kills your fuel mileage. But, if your truck is original with the dana 50 front axle, a f250 kit should fit it.
Old Nov 29, 2011 | 07:06 AM
Diesel_Brad
Yes, but no ride improvement. It will most likely make it worse, unless your truck is already riding on the bumpstops
