69 F250 Steering Problem
Old Mar 23, 2003 | 08:08 AM
Husky's Avatar
Husky
Question 69 F250 Steering Problem
I have replaced every bushing (except king pins), tie rods, link bar and steering box (all store bought). My truck still darts from side to side even after having it aligned. I noticed that the steering box I bought has some play in it. Is this normal for these old trucks? Has anyone else had these types of problems? Cure? (69 F250)
Old Mar 23, 2003 | 08:17 AM
460 Crew's Avatar
460 Crew
Husky
There is an adjuster on the top of the box itself. You just have to mess with it a lille bit to get some play out. Also are you running radial or bias tires,the bias will put you all over the road.
1970 F250 Crewcab 4x4 460 C6
Old Mar 23, 2003 | 08:29 AM
Husky's Avatar
Husky
I am running Goodyear Workhorse Radials and I have already made the gear box adjustments. It took out a little slop but not all of it.
Old Mar 23, 2003 | 08:35 AM
460 Crew's Avatar
460 Crew
Husky
What kind of shape is the rag joint in on the steering shaft, I know a worn out one had alot to do with my dads sloppy sterring on his 69 250?
Old Mar 23, 2003 | 09:19 AM
Husky's Avatar
Husky
That's in great shape as well. I assume the "rag joint" is the flex coupling between the steering column and the gear box.
Old Mar 23, 2003 | 09:03 PM
fast70's Avatar
fast70
shocks and springs will help with the darting
Old Mar 24, 2003 | 10:35 AM
70fordguy's Avatar
70fordguy
They'll wander around if the wheel bearings are a little loose too, adjust ment is easy and all it costs is a couple of cotter keys.
Old Mar 24, 2003 | 06:28 PM
Husky's Avatar
Husky
The shocks are new as well.
I'm going through the brakes this week so the wheel bearings will be adjusted correctly when I'm done.
Thanks for the help guy's!!!
Old Mar 24, 2003 | 07:46 PM
Mike W's Avatar
Mike W
Check the king pins for play. Mine was much more stable after I got some more caster put in by the alignment shop. Be careful on the steering gear adjustment. You can get it too tight and not know it unless you follow the <a href="http://motorhaven.autoanything.com/">shop manual</a> procedure.
lance65
Nov 8, 2016 05:56 PM
coloradotrk
Sep 4, 2015 09:43 PM
Shando69
16
Oct 29, 2013 02:26 PM
rambleramcnut
Nov 8, 2002 11:32 AM
