I recently purchased a 2004 lifted Excursion psd that has a 4 1/2 lift. I would like to drop it back down to close to original size and am looking for some info. I don't know much about the lift kit except that it has 4 1/2 inch blocks in the rear and the front has new leaf springs. There are also Bilstein shocks all the way around. Comparing it to other stock vehicles it doesn't appear to have a dropped pitman arm or any other mods. I use the word "appear" loosely because lift kits are very new to me.
I just picked up some used front leaf springs from a guy that has a 2004 Excursion also. Unfortunately, I just found out that there are about six different leaf springs for a 2004 alone! I believe this is because of different engines(his is a v10), tranny's etc....
Is there any way to find out the rating of the springs that I have purchased? the only numbers I can find are; 3C34AHA and RPN3083. They are both etched into the spring.
Any constructive thoughts would be appreciated.
Thanks
Reason: added wording
