Dirty Oil...again
Old May 9, 2011 | 04:56 PM
gliderdad's Avatar
gliderdad
Dirty Oil...again
I've got a 67 f250 ranger with a 352/ COM combo.
I flushed the motor and changed the oil 2x in the last 600 miles due to the oil turning black so quickly.
I just looked at the oil this weekend and the oil is black again with only 250 miles on it.
I have been using the Castrol high mileage 10-40 in it.
What is causing the oil to turn so quickly?
Old May 9, 2011 | 06:53 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
I saw it one time with an old penzoil engine I got, but I after the first time in 250 miles. I flushed with diesel oil, and used a drill to prime. That pretty much disolved all the "sludge", and primed with cheap oil. Then ran that for 500 miles, but it seemed normal for the age of the engine.
I've also seen it with extreme blow-by when the engine was richer then needed.
Old May 9, 2011 | 08:44 PM
Shawns Fords's Avatar
Shawns Fords
You probably have a lot of sludge build up inside that engine, as you run the fresh clean oil through it the sludge is loosening up and becoming part of your new oil.
Old May 10, 2011 | 11:46 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yep, if that's the original motor, any newer detergent oil is going to start melting away decades of paraffin buildup.
Just keep an eye on it. When it turns again, change it. And keep changing it.
Or pull it all apart and get rid of the sludge. But then you should just rebuild it, and so on and so on...
Pull the valve covers, I bet there's a bunch of it under there. Most of it, matter of fact. Be careful not to let anything get loose into the head drains. It might be the best way to get rid of most of the crud.
Old May 10, 2011 | 11:56 AM
OrangeJuice's Avatar
OrangeJuice
Maybe try running some Brad Penn break-in oil as it has a lot of detergents in the oil to help clean dirt out. I used it in my engine before and I don't have dirt build-up.
OJ
Old May 10, 2011 | 05:30 PM
69cj's Avatar
69cj
We used to add a pint of Marvel Mystery oil to the oil to clean things up. If it's really funky inside you'll never clean it all this way however.
Old May 10, 2011 | 09:05 PM
DeepRoots's Avatar
DeepRoots
gasket set $80
or if the sludge happens to go through the pump and past the filter you'll need a rebuild.
I don't know your situation, it might be your only driver, but I've pulled some motors apart that folks said "we run it everyday, it runs great"
after seeing the 5gallon bucket full of black crap when I'm done cleaning, I opt for the gasket set.
Under the valve covers and the tray above the lifters can hold ALOT of junk.
good luck,
Drew
Old May 12, 2011 | 09:22 PM
bamaf150's Avatar
bamaf150
Nothing unusual for high mileage engines, particularly older carberated ones, IME. If the oil is just black and not broken down, just change it every 3000 miles and dont worry about it. We used to have detroit diesels for irrigation units. The oil would be black as pitch, change it, crank it, check for leaks, shut it off and check oil level. The oil would be so black you would swear it hadnt been changed in years. Take it to the field and let it rip.
Old May 19, 2011 | 11:58 PM
gliderdad's Avatar
gliderdad
Thanks for the advice all....I will pull the valve covers and check for "extra crud" and flush the motor again. I need to change the Valve cover gaskets anyway..
I do have a small exhaust leak on the passenger side...would that have anything to do with the oil color changing so quickly?
Old May 20, 2011 | 08:35 AM
69cj's Avatar
69cj
In a word, NO!
jstihl
66
May 12, 2016 09:02 AM
speakerfritz
6.4L Power Stroke Diesel
Nov 25, 2015 08:27 AM
allcool
6.7L Power Stroke Diesel
Nov 19, 2015 07:11 PM
Jacob Willhoite
Aug 13, 2015 09:40 AM
Rockwell
Oil & Lubrication
13
Jun 9, 2003 10:33 PM
