duracolor primer
Old May 7, 2011 | 05:54 PM
68ranger704's Avatar
68ranger704
duracolor primer
i am about to begin doing some body work on my 68 and i was wondering if anyone here had any issues with the duracolor primer in the rattle cans. my delima is time i dont have the time to do all the sanding and filling and welding in a day or a weekend so i have decided to work on a fender then a door then a couple of spots here and there and i dont wanna leave the metal bare while i move around from spot to spot. ive never done much body work so i want to take my time and do the best job i can. will i have to remove all of this primer after i finish my body work and then re prime the whole truck? i have access to a spray gun and compressor setup and i have not decided on what brand paint to use on the final finish i am hopeing that mabey duracolor has a base coat clear coat that will go over their rattle can primer without any tragic reactions. this is their sandable primer thanks
Old May 7, 2011 | 08:32 PM
GLR's Avatar
GLR
Couldn't tell you for sure but, you might get more replies in the paint forum.
Old May 7, 2011 | 09:46 PM
MIKES 68 F100's Avatar
MIKES 68 F100
I'D STAY AWAY FROM RATTLE CANS IF YOU PLAN TO PAINT
use a urethane 2k primer you can spot prime the areas you fix then sand and prime the whole panel when you get the time.
Old May 7, 2011 | 10:29 PM
68ranger704
ok thanks i forget about all the other forums on fte
