Blinker wiring
Old May 7, 2011 | 11:34 AM
mfeveleth's Avatar
mfeveleth
Blinker wiring
Want to thank you all for your help in the past and I am needing some more of that expert advice again.
I have been trying to fix a brake light issue and had purchased a new harness, which was the wrong one, bummer!
Any way, my problem goes to when I first unpluged and removed the harness that came with the truck. I assumed it had the same wireing markings as in the trucks main plug and so I did not take a picture of it how the wires lined up in the plug.
I am now putting the original harness back in the truck for the horn and such but when I went to match the wires with the trucks main plug they were not the same, so How can I get an original wiring skematic so I can try to match up my blinker harness properly? I did figure out the horn, but not sure how the rest of the wires match up.
Thanks for your help
Old May 7, 2011 | 05:43 PM
VocaTexas's Avatar
VocaTexas
What year model are you talking about? Makes a difference...
Old May 7, 2011 | 11:13 PM
mfeveleth's Avatar
mfeveleth
Sorry, 78 f250 camper special notilt, steering wheel, automatic
Old May 8, 2011 | 01:52 AM
VocaTexas's Avatar
VocaTexas
I've got a Chilton's manual that covers Ford Pick-ups from '76 to '86 that has wiring and vacuum diagrams, plus tons more great info. A Ford shop manual would be more detailed, but for most people this one would probably suffice.
The part number for the manual is 8576. ISBN 0-8019-8576-5. I got mine from my local NAPA store. I've also seen them on the shelf at Hasting's Books.
Old May 8, 2011 | 09:24 AM
mfeveleth's Avatar
mfeveleth
Thanks I will find one
Old May 9, 2011 | 02:06 PM
73FOMO's Avatar
73FOMO
Are you talking about rear light wire colors? I'm a little confused...but maybe this helps.
Brown _ LH and RH Rear Lamp and Marker Lamp, License Lamps (running lights)
Yellow/Black Stripe _ LH Rear Lamp
Solid Green_RH Rear Lamp
Black/Red Stripe_LH and RH Backup lamps
__________________
Old May 9, 2011 | 06:03 PM
mfeveleth's Avatar
mfeveleth
That might help but to be sure we are on the same page. I am taking about the plug that the blinker harness plugs into under the dash by the steering column. Like I mentioned I did figure out the horn wires so I can opperate my horn, I do not know where to begin to hook up the taillights, blinker lights, hazzards etc. I do have a chilton's coming but any other help would be appreciated.
