Help NumberDummy
Old 05-06-2011, 12:34 PM
Green Griffin 420's Avatar
Green Griffin 420
Green Griffin 420 is offline
Help NumberDummy
I was told you were the man that could help me out.
What I need is a single part number for f150 lightning front coil springs.
Old 05-06-2011, 12:41 PM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
What about the proximity sensor?
Old 05-06-2011, 02:07 PM
Green Griffin 420
Wound up being the TPS.
Old 05-06-2011, 03:54 PM
thechief66's Avatar
thechief66
thechief66 is offline
To find Ford coil springs, you'll need the year of the truck and a spring code, which is located at the bottom of the build sticker on the drivers doorjamb.
Old 05-06-2011, 09:21 PM
Green Griffin 420
thanks for the info. I don't have a lightning I have a XLT and I want to lower the front just a little bit. I was told that the lightning springs would work and they would drop the front about an inch.
Old 05-06-2011, 11:11 PM
86F150302's Avatar
86F150302
86F150302 is offline
P4J is the spring code on my 94 Lightning.
Should be F3TA-5310-SA.
There are some beltech springs and stock L leafs on NLOC right now.
Actually here are some stock springs.
http://www.nloc.net/classifieds/show...-springs&cat=3
Old 05-07-2011, 09:42 PM
Green Griffin 420
Thanks 86f150302. I sent him a message.
Old 05-09-2011, 10:50 AM
Green Griffin 420
Thanks for the help guys.
460lover
Arizona Chapter
10-15-2016 03:52 PM
kburk
New Member Introductions
06-22-2005 07:56 PM
ford429cu
09-13-2002 08:46 PM
CobraXP
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
07-15-2002 01:31 PM
KevinT
01-08-2001 10:23 PM
Quick Reply: Help NumberDummy
