What is my bolt pattern?
Old Mar 22, 2003 | 01:13 PM
knocturnal's Avatar
knocturnal
ok guys... 92 f150 custom 2wd, 300 i-6 m5od just wanna know what my bolt pattern is.. and would the first generation lightning wheels fit on my truck?
Old Mar 22, 2003 | 02:09 PM
StrangeRanger's Avatar
StrangeRanger
5 x 5.5" same as the Lightning and most other Ford and Dodge half tons up until the present body style. FWIW your stock back spacing is 4.25" with a 7.5" wide wheel which works out to a zero offset if your rim manufacturer specifies their wheels that way. On my 96 I went to 8" wheels with 4.5" backspacing (also zero offset) with no problems and a bit of room to spare.
Shop around Lightning wheels are usually expensive and are prone to the paint peeling. You can usually do better for less,
Old Mar 22, 2003 | 02:16 PM
knocturnal's Avatar
knocturnal
ok i finally know my bolt pattern.. can i get a lil more info on backspacing?
Old Mar 22, 2003 | 03:01 PM
StrangeRanger
What do you need to know?
Old Mar 22, 2003 | 10:37 PM
knocturnal's Avatar
knocturnal
how does a more or less back spacing affect my handling and all that...
Old Mar 22, 2003 | 11:35 PM
steve83's Avatar
steve83
Less backspacing causes the tires to swing a wider arc as you steer, and can affect tracking, caster, camber, return-to-center, steering force, bumpsteer, & wheel bearing life. Front end alignment is complex & delicate, so read up before you mess with it. You can probably find a steering article I OCR'ed on BroncoData.com, or you might be able to dl it (without the pics) by clicking here. Think about the line from the upper ball joint thru the lower down to the ground, and where it intersects the line straight down thru the tire.
