bills52
Old May 6, 2011 | 09:54 AM
bills52's Avatar
bills52
bills52
Can someone tell me how to remove the door lock on my 52 drivers side. I dont have a key and want to replace the lock. Thanks Bill
Old May 6, 2011 | 10:06 AM
firstrider's Avatar
firstrider
Look under the door weather strip seal adjacent to the lock . The lock is held in place by a long set screw . If you have any luck at all it won't be rusted in place . If it is you will be entering another post asking how to remove it . Good luck !! Might want to enter '52 door lock in the search criteria . This has been discusssed before . Later , Denny
Old May 6, 2011 | 10:16 AM
bills52's Avatar
bills52
Thank you I will try the door lock search. Bill
Old May 7, 2011 | 12:10 AM
51PanelMan's Avatar
51PanelMan
You may need to peel away the door weatherstripping slightly as the hole for the set screw is hidden by the weatherstripping most of the time. The screw is usually an allen head. As Denny mentioned, hopefully it was be frozen from the rust. Spray some penetrant for a few days on it and let it soak before trying to remove it.
Another way to avoid this trouble is to have your door lock cylinders re-keyed to match the ignition or have a new key cut. Any professional and experienced locksmith can do that. Usually would cost you $25-35 or so. I'd go that route first.
Old May 7, 2011 | 06:46 AM
bills52's Avatar
bills52
Thanks for the info I found that I have locks on both doors so i am working on the drivers door now and I am going to try and drill out the set screw and then get a replacement. Let you know how it turns out. Thanks again. Bill
tractormanbill
Nov 26, 2012 09:30 PM
tractormanbill
15
Nov 2, 2011 01:02 PM
cts1954
Apr 22, 2010 08:54 PM
novatattoo
17
Jan 8, 2006 08:54 AM
novatattoo
15
Sep 12, 2005 03:18 PM
