Electrical issues!
Old May 5, 2011 | 09:39 PM
nix4x4's Avatar
nix4x4
Electrical issues!
Where are the connections for the instrument cluster wiring located?
Where do they run to? My lights in the cluster won't light up,
and the oil pressure and battery charge gauges aren't working.
I have checked fuses, I'm just not good at tracing out wiring.
Old May 6, 2011 | 07:21 AM
DBGrif91's Avatar
DBGrif91
If I'm not mistaken, there should just be one or two plugs that plug in directly to the dash. Remove enough pieces to remove the instruments, and the plugs should be right on the backside. Maybe try looking up from underneath to see for sure?
Old May 6, 2011 | 10:41 AM
SideWinder4.9l's Avatar
SideWinder4.9l
92-96 era has a wire bundle/plug for each section of the cluster....1 for the speedo, 1 for the temp/charging, etc.....
