upgrade
Old May 5, 2011 | 05:48 PM
d-brack's Avatar
d-brack
upgrade
i have i 91 f250, its been upgraded to a dually but my drivetrain wont hold up to wat i need to pull. gutted a rearend today, a buddy told me that i should be able to upgrade to superduty axles and take care of the issue.. any idea on if you can do that or tips on how to make it easier,???
i foound a place i can buy front and rear axles off a superduty being a straight axl superduty idk how convert my twin i-beam over to that???? help
Old May 5, 2011 | 05:56 PM
Edgethis's Avatar
Edgethis
I don't see why you really need to convert to a solid axle up front if you're rear is not holding up. How much are you trying to tow/haul? Also what rear do you have now. You mentioned a dually conversion. Was that a whole axle or just hub adapters?
Old May 5, 2011 | 06:00 PM
Edgethis's Avatar
Edgethis
Also what motor/ trans are you running? Are you pulling a fifth wheel or standard hitch trailer? Have you thought about upgrading the axle shafts and gears before swapping a whole axle?
