Sponsored by: Real Truck
Source for hub Dials Only?
Old May 13, 2011 | 09:17 AM
EMC V10 X's Avatar
EMC V10 X
Originally Posted by p-nut
The diaphragm can be removed. I did. Cleaned and reinstalled. Been working like a champ for years.
How did you do it? I have one that needs done and I cant figure out how to remove the dial without ruining the diaphragm.
Old May 13, 2011 | 09:28 AM
dkf's Avatar
dkf
And if you damage the diaphragm your done.(vaccum leak) I found no replacements for it.(diaphragm) I pulled the diaphagm on the hub anyway to get to the dial as suspected the hub was shot anyway. Turned out my suspicions were right, the dial channel was corroded that bad it needed replacing.
Old May 18, 2011 | 05:17 AM
AirborneCav's Avatar
AirborneCav
I installed the hubs on my F350 dually with Mile Marker Premiums also. The look much better (shiny to match rim) and work great! It is a quick fix and the cost was around $150 for me with the conversion kit.
vortec 1
Nov 12, 2014 10:38 PM
DanielT28
Oct 1, 2014 07:49 PM
montana_highboy
Jan 31, 2013 05:52 PM
gvb
Sep 3, 2011 04:17 PM
joeycyph56
Oct 6, 2010 10:19 AM
