Tru Cool cooler
Old May 4, 2011 | 08:57 AM
grizzly11's Avatar
grizzly11
Tru Cool cooler
my trans hit 220 one time on the interstate and ever since i have been afraid of getting it to hot. I have been doing some scrap metal and on day that OAT was around 50-60F i seen temps from 140-150 pulling the trailer was 6000lbs loaded that includes the trailer itself. I got a tru cool cooler for 28,000lbs. not the max one is this one just as good?
Old May 4, 2011 | 10:30 AM
HH60FE's Avatar
HH60FE
Griz, My thoughts are that it will help, how much? Don't know. Install it and see. 50% of something is better than 100% of nothing.
Old May 4, 2011 | 10:55 AM
clintbonnie's Avatar
clintbonnie
Were you pulling a hill when it got to 220* with a load ? I have never been that hot on the freeway with my truck, even pulling a mountain pass.. You might a something else going on to bring the temps up that high..The only time I get up around 200* is pulling a load thru town, with stop and go thru stop lights, using 1st and 2nd gear alot.. and the torque converter working extra hard..
Old May 4, 2011 | 01:09 PM
grizzly11's Avatar
grizzly11
the 220 was unloaded on a flat interstate with minor hills i thought the stock cooler was pluged so i blew out both the OTA and OTW coolers and havent seen anything that high since. I should be instaling tonight or tomarrow i will post back results
Old May 4, 2011 | 02:05 PM
Firefighter 1406's Avatar
Firefighter 1406
I have seen temps that high with mine. But that was snowplowing a lot, so no air movement. I now have an electric fan sucking air thru my larger cooler, havent had any problems since then. When it starts to get hot plowing I flip the switch and watch the gauge go down. Also change my fluid about every 20,000.
Old May 4, 2011 | 03:42 PM
grizzly11's Avatar
grizzly11
I just went and picked up a magnefine inline filter to put in to. The filter goes on the return line correct
Old May 5, 2011 | 11:17 AM
grizzly11's Avatar
grizzly11
temps seamed to warm up faster but then after 80F they very slowly heated up then i was at school so i couldnt run it any more i was looking in a VB now what sets BTS and JW apart and PHP should beable to tune my chip for it correct.
Old May 5, 2011 | 12:09 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yes, PHP can change the calibrations for the valve body. Just be aware that the only thing the valve body will do for you is mechanically increase the flow rates through the valve body instead of doing it electrically with increased pressure.
EDIT:
Oh, and the new switches are $25 each plus shipping.
Old May 5, 2011 | 01:10 PM
grizzly11's Avatar
grizzly11
so its pointless to get a VB? and thanks cody i will have to get one. I just take the old switch out of the chip and then plug the new one in correct? And do i order it through you guys or ts?
Old May 5, 2011 | 01:18 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
You'd have to get it through us (or another TS dealer). Simple plug/play.
The valve body doesn't strengthen the transmission, it just alters shift feel by mechanical means and larger orifices rather than just raising pressure to get the same flow.
Old May 5, 2011 | 01:49 PM
grizzly11's Avatar
grizzly11
ok cody what should i do to help strenghten the trans a trugger HD2 shift kit?
Old May 6, 2011 | 08:31 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Any "shift kit" is just going to alter transmission pressures (although without actually modifying the orifices IN the valve body).
To strengthen the transmission, you actually have to get into the actual power-flow hard parts....the parts that actually have to withstand the power.
Old May 6, 2011 | 09:39 AM
grizzly11's Avatar
grizzly11
Ok sounds good time will only tell
Old May 6, 2011 | 01:30 PM
grizzly11's Avatar
grizzly11
would a TC lockup switch help anything just looking for small mods right now the bank has run dry. How hard would it be? The reason im asking is bc sometimes in town around 38-40mph i can see the tach move up and down likes its locking and unlocking.
squaredancer
Nov 16, 2012 08:34 AM
Joe28443
Feb 26, 2010 02:15 PM
johnsjsj
Apr 14, 2007 10:25 AM
cangim
Jul 18, 2005 04:14 AM
