doing a head gasget tomorrow
Old May 3, 2011 | 05:38 PM
hulklil87gt's Avatar
hulklil87gt
hey guys i am pulling the motor in my truck tomorrow. Had a misfire after full tune up checked plugs over looked good, did a compression test on number 2 cyl. and got 50psi tested #3 and got 150 and i got 55psi on the #1 cyl. so i looked up on alldata and seen it said "If two adjacent cylinders indicate low compression pressures and squirting oil on pistons does not increase compression, cause may be a cylinder head gasket leak between cylinders. Engine oil and/or coolant in cylinders could result from this problem". I put oil in the cyl and still got the same reading. i am just wounder if any has had this same problem and hoping i am going in the right direction thanks.
Old May 3, 2011 | 07:45 PM
ctubutis's Avatar
ctubutis
I don't understand why you want to pull the entire engine instead of just the head(s).
A leak down test would help you confirm your diagnosis, e.g.
What is a "leak down" test? — Yahoo! Autos
Listen for air from the exhaust, carb & oil fill hole in the valve cover, look for bubbles in the radiator.
Old May 3, 2011 | 07:58 PM
hulklil87gt
Im pulling it because I have a rear main seal and oil pan and timing cover gasget leak so. Im doing everything in one shot
