plugs seized.....
Old May 3, 2011 | 01:03 AM
ryito1122334455's Avatar
ryito1122334455
plugs seized.....
did a partial tune up today, got the last 4/6 plugs changed, but the first 2 are stuck in there, what do you recomend to get em out to change em........specs are in profile thanks
Old May 3, 2011 | 01:13 AM
timbersteel's Avatar
timbersteel
Spray PB blaster around the threaded portion in the block. Let soak. Drive or let idle for 5 mins. With engine warm(Not hot) see if they will break loose. If not try again. Could just take some effort with penetrant and heat. Be careful not to strip the threads or break a plug.
Old May 3, 2011 | 01:54 AM
zxwut?'s Avatar
zxwut?
And make sure to use some anti-seize on the new plugs so you don't have the same problem next time.
Old May 3, 2011 | 02:12 AM
deeznuts822's Avatar
deeznuts822
I would spray them and drive for a couple days,giving them a nice spray each day,they should come right out
Old May 5, 2011 | 02:14 AM
ryito1122334455
im so nervous..........i dont wanna snap my plugs.....
Old May 13, 2011 | 04:46 PM
Eicca's Avatar
Eicca
At least the I6 head is probably easier to take off in the event of a broken plug that won't come out after you've busted 10 sockets and stripped the EZOut head...
Jackedup07
1997 - 2003 F150
13
Dec 22, 2012 02:17 PM
guthrie&co
Feb 2, 2009 11:56 PM
Gevans17
Modular V8 (4.6L, 5.4L)
Dec 4, 2006 05:52 PM
Thunder_1
16
Sep 25, 2005 01:22 PM
cooter4x
Jul 8, 2002 11:29 PM
