Engine missing, shaking truck
Old May 2, 2011 | 10:33 PM
quality1construction's Avatar
I now have a miss in the engine it shakes pretty good like a cammed up big block at the lights!. It does not go away, just smoothes out a little when you get up to 2500 rpm or when you let off the throttle, but not entirely. I have replaced all glow plugs, gpr, uvc harnesses, changed oil regularly, All injectors ohm out. Does this sounds more like a compression issue or bad injectors or turbo going south? Any ideas or thoughts? The check engine light is not on, no water in the oil, no leaks.
Old May 2, 2011 | 11:58 PM
richdawg's Avatar
richdawg
Do you have a manual trans and a dual mass clutch and flywheel?
Old May 3, 2011 | 05:27 AM
I have the 6spd trans, but solid flywheel and new clutch about 10k ago.
Old May 3, 2011 | 07:00 AM
riverrat41's Avatar
riverrat41
Might check the 42 pin connector for fraying.If it is arching it could act like this.Unplug the CPS and check to see if it is dry in the connection.
Old May 3, 2011 | 07:15 AM
EMD_DRIVER's Avatar
EMD_DRIVER
My truck was doing the same thing and it turned out to be a bad injector. Your best bet, is to get the truck on a scanner and run a cylinder contribution test. That will show you, if it is a weak/bad injector.
