tail light out
Old May 2, 2011 | 09:37 AM
Brown_76_f-100's Avatar
Brown_76_f-100
tail light out
hey everybody i have a problem, any help would be appreciated. on the drivers side everything works. on the passenger side my turn signal and brake light works but not my tail light. also the bedside marker light is out. don't know if that could have something to do with it or not. i changed the light socket and cleaned up the ground for the tail light but its still out. any ideas? thanks
Old May 2, 2011 | 11:28 AM
ford4604bbl's Avatar
ford4604bbl
check the wiring and make sure you are getting juice to the plug if you are then it could be a bad ground, check the ground wire where it screws in and clean it up. if not the socket could be bad and then you would have to replace the socket.
Old May 2, 2011 | 12:41 PM
LongTravelHighboy's Avatar
LongTravelHighboy
did ya change the bulb? seems simple, but my other bulb just went out and thats all it was.
