Drafting a semi
Old May 4, 2011 | 10:14 AM
  #31
TheBestKindOfEX's Avatar
TheBestKindOfEX
Opinions are like *********s...everyone has one and most stink
Old May 4, 2011 | 12:54 PM
  #32
1 Excursion camper's Avatar
1 Excursion camper
I`ve had peple try and do that behind my trailer in everything from minivans to little Hondas. I`m glad that I have a camera on the back of my trailer so I can see just where they are at. they don`t like it very much when I slow down to 53mph. thta`s when they pull out and go around me. the last time it happened was on our way back from the Smoky`s. I get terrible mileage as it is, I`m not pulling someone else too.
DO NOT FOLLOW ANYONE THAT CLOSE EVER! you cannot see what is going on in front of the vehicle you are tailgating.
Old May 4, 2011 | 01:54 PM
  #33
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I have people try to draft off me when I'm just driving my F250! Empty, no trailer, but they want to crawl up on me and hover there. 53 works pretty good to "shake them loose". I'll "draft" at about 100' back from a semi, because that's where I'm comfortable. To each their own.
Old May 4, 2011 | 03:08 PM
  #34
fatherdano's Avatar
fatherdano
An Excursion was not built to follow, rather to be followed.
Old May 4, 2011 | 03:25 PM
  #35
hanklin's Avatar
hanklin
Dam thats good!!! Reps to you my friend
Old May 4, 2011 | 06:39 PM
  #36
Snowseeker's Avatar
Snowseeker
That would be nice to have! How is that wired? With just a RC plug out the back door? I am looking to put dvd/navigation in the dash of my X this summer and want a back up camera (already have the camera) on the back of the X to see when I am backing up to trailers. If I could set up one on the back of the camper that would be very nice for backing into camping spots and just knowing whats back there when backing up.
Old May 4, 2011 | 07:48 PM
  #37
TheBestKindOfEX
camera....hijacked the drafters
I have both cameras also. My hitch cam is wireless and my rear trailer cam is hard-wired. The feed wires are bundled with the trailer harness at the hitch. The wires on the Ex are just zip tied next to the trailer plug. There are two wires for the camera connection. One power wire and one quick connect for the video feed.
I put the trailer cam on the rear ladder at the top, and ran the wires down the ladder rails to under the camper. Pretty easy install. Both cams are night vision cams and work very well in low or no light.
Edit---I ran the wires for the trailer cam from under the dash down the drivers side under the plastic trim. Behind the 3rd row bench I went under the carpet and spare tire carrier to one of the grommets in the floor pan. I just pulled the wire to the trailer connector under the rear bumper and zip tied it there. It's fairly well protected from the elements and is an easy connection to the wires coming from the trailer.
Last edited by TheBestKindOfEX; May 4, 2011 at 08:12 PM. Reason: added portion about excursion wiring
Old May 4, 2011 | 07:53 PM
  #38
1 Excursion camper
My wife got me one of the last "wired" VR3 cameras from Pepboys years ago. I just cut the camera wire and extended it so I could mount it on the rear of the trailer just a little higher than 1/2 way up the wall. I mounted it so that it clips in under the siding. Yes the screen is a little small, but it`s better than the view I had before, which was nothing!
Very good fatherdano, I like it!
Old May 4, 2011 | 11:21 PM
  #39
Red Ex's Avatar
Red Ex
I have this License plate camera on the Ex LICENSE MOUNT COLOR CCD REAR VIEW BACKUP CAMERA TAG | eBay
and this camera with 49' cable on the trailer - COLOR CCD REAR VIEW CAMERA BACKUP SAFETY + 32' CABLE | eBay
Just installed the trailer camera in place of the top center running light. Used the hole that was left behind from the light to fish the cable through. I ran the cable to the front of the trailer in the underbelly. On the Ex the camera has a 4 pt DIN connection that screws together for a nice tight connection. I left this connection right next to the trailer connection. When I hook the trailer I just unplug the Ex camera and plug in the trailer camera. I have a Kenwood DNX8120 DVD/Nav deck that shows the rear camera any time it is in reverse or if you simply hold a button for 2 seconds. Works great. We have a 300' drive way that winds in around some trees. I usually back down the drive as it is faster than turning around at the end. With the camera it is simple to back in the dark as it works very well day or night. Makes hooking up the trailer simple also.
Old May 4, 2011 | 11:53 PM
  #40
brickie's Avatar
brickie
Spend a few bucks on mods to the truck,my 8000lb 350 gets 20mpg at 70-75mph highway passing anything slower than 70.
Old May 5, 2011 | 08:03 AM
  #41
Snowseeker's Avatar
Snowseeker
That first camera is kinda like the one I got but it is more square. It had a license plate mount on it but I removed the mount and everything else it didn't need. I will be mounting it next to the rear glass latch handle by drilling a hole threw the molding. Either that or up by the 3rd brake light.
Thanks for the trailer camera link. Would be nice to not have to cut the camera wire if I don't have to.
Since I pull a boat behind the TT it would also be nice with the camera so I can check in on the boat now and then while traveling because as of now I don't see it at all unless I am turning a corner.
Old May 5, 2011 | 08:36 AM
  #42
BassFantasizer's Avatar
BassFantasizer
How are you mounting the display? There's not a lot of places to attractively mount a 6" or even 4" monitor.
Better yet, can you post pictures of the display?
Old May 5, 2011 | 09:23 AM
  #43
TheBestKindOfEX
Here's how mine is mounted
Old May 5, 2011 | 09:31 AM
  #44
BassFantasizer
Now that's good looking! Great job!
Old May 5, 2011 | 09:42 AM
  #45
dchamberlain's Avatar
dchamberlain
60 MPH is 88 feet per second.
1 car length is what? Let's say 10 feet.
Your time to react to anything that happens on or with that truck is .11 seconds.
Average human reaction time is .15 to .30 seconds.
So, anything that comes off of that truck, or it hits and throws up, or whatever, is going to hit you before you can see it and react.
