Oil & Lubrication
Engine oil
Old Mar 21, 2003 | 05:55 PM
BulldogKen's Avatar
BulldogKen
Engine oil
What type weight of oil is recommended for a 1995 Ford F150 5.8L engine. Also what is the cubic inch of a 5.8L engine. Any comments on the 1995 F150 good or bad is most welcome.
BulldogKen
Old Mar 21, 2003 | 06:28 PM
khmorse's Avatar
khmorse
Engine oil
Welcome to FTE.
It should be a 5w30 for your engine and year truck. You can find a whole lot of debates on the best brands, weights, and types of oils in the oil & lubrication forum.
https://www.ford-trucks.com/forums/f...?s=&forumid=70
Hope this helps.
Old Mar 21, 2003 | 06:29 PM
khmorse's Avatar
khmorse
Engine oil
Also,
the 5.8L is a 330 CI eng.
Old Mar 21, 2003 | 08:20 PM
Flash's Avatar
Flash
Engine oil
The original oil spec on your truck was an API SG rated oil. Best of luck trying to find any as the motor oils of today are much better than that. Any SJ or SL API certified oil will do, the SL is the better of the the two. The 5.8 engine is 351 cubic inches.
Old Mar 21, 2003 | 08:21 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Engine oil
10W30 and 5.8=351
