Pop Tester
Old Apr 30, 2011 | 07:42 PM
84-6.9L's Avatar
84-6.9L
Question Pop Tester
So I'm looking at building a pop tester for injectors because my buddy and i are trying to get a small tractor repair business going and i would like to do my own injector work, it seems simple enough to do there ain't much to an injector, and at the very minimum i can locate bad injectors and just get the bad ones serviced. Anywho i plan on using a pump for a shop press what i need to locate is an afordable gauge that reads up to 3000psi and where would i locate fittings to adapt to injector line, and also what are the most popular linjector threading? Is there a place i could go to to get these lines made?
Heres the pump I'm thinking about using
Torin Big Red Hydraulic Ram Pump — 10-Ton Capacity, Model# T71101 | Rams + Ram Kits | Northern Tool + Equipment
kotterr
Large Truck
Jan 24, 2013 11:43 PM
ghunt
Feb 20, 2011 10:34 PM
Homelessduck
24
Sep 16, 2007 11:39 PM
Hondasucks
Feb 3, 2006 03:39 PM
