cold start and rough idle
Old Mar 21, 2003 | 01:49 PM
iamme9182's Avatar
iamme9182
i have an 81 f-250, just replaced the carb. when i start the truck cold it starts to sputter as i push the gas. i have to push the gas slow until it starts to sputter then let off and do it again. i have to do this a few times then it runs fine until im at a stop, then it idles very rough. any ideas what might be a cause of this?
Old Mar 21, 2003 | 01:51 PM
iamme9182's Avatar
iamme9182
oh yeah and it feels like when it sits there for a period of time that there is no gas available to the engine when you push the gas.
Old Mar 23, 2003 | 02:10 PM
cbwarrior's Avatar
cbwarrior
Is the choke set up properly?
Old Mar 24, 2003 | 05:21 PM
goldnewf's Avatar
goldnewf
Angry cold start and rough idle
I'm having a similiar problem. I have a 1982 F150 4x4 with a 351W. It will turn over for a couple of minutes then quit. When you try again, it will not start. I replaced the fuel pump and I have lots of gas. There is a blue spark. I replaced the carburator with a used one from the junk yard over a month ago. It was starting and running good up to a week ago. We checked the timing and it appears to be ok. This has really stumped us. Does anyone have any suggestions for me.
Jo
Old Mar 24, 2003 | 06:08 PM
Franklin2's Avatar
Franklin2
Like the other poster said, check the choke. On a morning after it has set overnight, pull the aircleaner off. Take your hand and push the throttle wide open(don't start the truck yet), and let go. The choke flapper in the top of the carb should slam shut. Now go start it, and it should fast idle, and go back out and look, and the choke should have a small crack showing. Let it run for a minute or two, and then goose the throttle. The choke should open a little more, and the idle should drop a little. If the choke is staying shut, or is wide open, it's broke. 9 times out of 10 for me it's been the heater element in the round black choke housing. And they are expensive.
Also if you want to make the choke open faster or slower, you can loosen the screws on the round black choke housing(if it hasn't been rebuilt, it may have rivets), and turn it richer or leaner to adjust the choke.
If you look at the diagram below, they call the black thing you adjust a "thermostatic spring housing"
Old Mar 25, 2003 | 10:16 AM
goldnewf's Avatar
goldnewf
Thanks for the advice. We did this and the choke is working properly. Still not able to start. All advice welcomed.
