hesitating??????
Old Apr 29, 2011 | 12:30 PM
kosher88's Avatar
kosher88
hesitating??????
Ok i have a 1995 F250 4x4 351 Manual. It has been hesitating for a while now. I'm not sure what it could be. It seems worse on wet days so i thought it could be my dist. cap and rotor button. I replaced both and it made no difference at all. It feels like it isn't getting enough gas at times but the wet weather thing made me think electrical. My front tank has a bad fuel pump in it (i plan on replacing very soon) so i am forced to use the rear tank. I just receiently replaced the rear tank but this problem has persisted for a long time. I need some help here. Oh, and if it hesitates and i press the clutch down and rev it, it sounds great so i kinda ruled out the tranny slipping. Clutch kit has about 10000 on it and im not rough on it. Any help would be appreciated. Thank you
Old Apr 29, 2011 | 12:58 PM
GBuckert's Avatar
GBuckert
Fuel filter? Could be gummed up enough to not deliver enough fuel quickly enough when under load. Don't know how that would effect the free rev situation though.
Old Apr 29, 2011 | 01:10 PM
Lazy K's Avatar
Lazy K
What GB says and are your spark plugs and wires good?
Old Apr 29, 2011 | 02:03 PM
kosher88's Avatar
kosher88
Thanks guys....I thought about the fuel filter but as you did i ruled it out because of the free revving My plugs and wires are about five years old now so i guess i should change them too. wouldn't the truck miss and all this when i just rev it out of gear??? i guess everything changes when you put a load on it. I just don't want to put a lot of money into it trying to figure it out. Moneys tight got a baby on the way!
Thanks for the quick reply. i really appreciate it.
Old Apr 29, 2011 | 02:06 PM
GBuckert's Avatar
GBuckert
I would think so, unless they're just on the edge of being shot so the added stress of the load is just enough to keep them from working right. But that's just me thinking out loud. Did you ever pull codes? Maybe a bad TPS or something causing a lagging issue?
Old May 3, 2011 | 08:18 AM
kosher88's Avatar
kosher88
My check engine light is not on so would pulling codes have any benefit?? i am short on money currently and dont drive the truck everyday so i will try to get plugs and wire as soon as possible and post a reply with the results. Thanks so much for the reply
Old May 3, 2011 | 08:31 AM
GBuckert's Avatar
GBuckert
Codes don't always trip the light. My light actually seems to be burnt out as a code reader was the only thing that'd work. If you have an Advanced Auto or O'Reily's nearby you can pull them yourself for free. I just had to give them my driver's license as collateral.
Old May 3, 2011 | 08:35 AM
kosher88's Avatar
kosher88
Great i will do that this weekend as i need to run right by an advanced auto. Do i need any special instruction or will they explain this all to me? Thanks
Old May 3, 2011 | 12:48 PM
GBuckert's Avatar
GBuckert
I'm sure they can help you out. The scanner I used had step-by-step instructions on the screen.
Old May 3, 2011 | 12:50 PM
kosher88's Avatar
kosher88
Great thanks
Nobody39
Oct 31, 2014 02:45 PM
bradackman
1997 - 2003 F150
Apr 24, 2011 11:23 PM
rmdohen
Oct 4, 2010 08:00 PM
the_fitter
Jul 2, 2009 06:40 PM
ranger_ron
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 23, 2006 07:30 PM
