Hey guys Im a newbie here and I have a quick question.. I have a 98 expedition but the a/c only works on high. Is there anything I should check before I take it to a shop?
Is it just the A/C or do you mean the blower motor speed only works on the highest setting?
If that's the case, replace the blower motor resistor. It's located behind/under the glove box area.
Do a quick search on here for that and I'm sure you'll find what you're looking for
Thanks, yea its the blower motor itself, wont work on any setting besides the high position. Thanks Ill change that see if thats it When you say under the glove box area, you mean inside the cabing correct?
