Cleaning rusty frames
Old Mar 21, 2003 | 06:57 AM
AmeriKen's Avatar
AmeriKen
I have learned while cleaning tractors and small dozers in my hobby that the thick layered rust on the heavy gauge parts have to be attacked with an impact. There are pneumatic descalers that are available that have pins driven by the impact gun. This seems to be very effective removing the thick stuff before attempting to use a sand blaster. You can move along the truck frame at a good pace.
I have, also, used my pneumatic impact gun (muffler splitter) with a dulled chisel point. The heavy rust "flies" when it is attacked. You can get into the recesses easily.
On my dozers, the undercarriages are extremely rusty, and it does a good 1st step in the job of rust removal and preparation.
It is fairly quick to clean the surface and leaves less work to be done with a sandblaster.
Of course, this only works on heavy metal. The sheet metals will either be punched or dented using this method.
Afterwards, I use a cupped wire wheel on the body grinder. This is very effective, but body protection is needed. After a wire wheel job, I usually have my clothing penetrated with "wire darts" letting loose from the wire wheel.
Ken McWilliams
Dayton, OH
Old Mar 21, 2003 | 08:05 AM
286merc's Avatar
286merc
Good points on the impact gun Ken.
Another rust loosener is something called Prep Step Powder. It mixes with water and is applied over the rust. It softens the very thick scale and it can be removed with a putty knife, wide faced wood chisel or muffler gun.
I dont kow the chemistry involved but suspect it is a mild Phosphoric Acid.
One thing for certain, all methods make a mess!
Old Mar 21, 2003 | 09:31 PM
57_ford's Avatar
57_ford
A neddle scaler. My work bought one last fall and some poor guy had to do about 50 snow plows. It did a very good job. It looked like it would not take much sand blasting to finsh the job. Very Very loud.
AmeriKen
Aug 17, 2004 03:47 PM
AmeriKen
Apr 17, 2003 02:52 PM
AmeriKen
Feb 9, 2003 03:48 PM
AmeriKen
Jan 22, 2003 08:57 PM
AmeriKen
21
Dec 19, 2002 12:38 PM
