I was wondering because i broke my driver side steering knuckle on my 79 f-250 with dana 60 front if any other year knuckle would fit. i know they used king pins from 78-91.5 but are the knuckles the same for those years?
Thanks in Advance,Matt
Copied directly from page 2 of the Dana 60 bible on pirate!
Do the Ford kingpin knuckles for the '86 to '92 (or about there) D-60's interchange with the '78-'79 Ford HP D-60? *
Ford Dana 60 knuckles, from 1985 to 1991 will fit, but the taper for the tie rod is the next size smaller
I put gussets and plate on mine welded with a high nickel rod with pre heat then slow cooled in a dry bucket of sand along with my hydro assist steering upgrade to handle the extra stress. As stated in the d60 bible ford knuckles are prone to cracking over chev/ dodge so beef your junk up.
