Correct Running Temp?
Old Apr 27, 2011 | 06:02 PM
nothercrash's Avatar
nothercrash
I have a 400 with stock heads for now, probably Aussies in a month or so.
I have an aftermarket temp gauge hooked up but I don't even know what temperature is OK!
What temp will stuff really start to fail at? What is "overheated" maybe?
What is a good, average/normal, and high acceptable running temp for this engine?
Thanks for any info, AleX
Old Apr 28, 2011 | 01:13 AM
smokeyb97's Avatar
smokeyb97
I wish I knew for sure. Since Ford put 192 degree thermostats in these engines from the factory, I would think 200-210 degrees would not be bad on the engine. I understand the hotter we can run a motor without damaging anything would be idea because we would burn the fuel a lot better and have less sludge build-up. My engine has a high volume water pump and a 192 degree thermostat and runs around 160 degrees. I have to block off part of the radiator in winter to get it warmer.
Bigtruc
20
Dec 26, 2013 10:24 AM
Rushmore X
May 22, 2013 09:27 PM
Ford are best
May 6, 2013 08:16 AM
UNTAMND
Jan 10, 2012 04:25 PM
dave thomas
Oct 1, 2001 11:07 AM
