Timing Belt?
Old Mar 21, 2003 | 01:02 AM
fordenthusiast's Avatar
fordenthusiast
Timing Belt?
Hey if someone can offer me advice: every morn when i go to work and start up my truck it screeches with the ugliest sound- I have narrowed it down thinking maybe the timing belt? I bought with 50K, and never have had it changed- can anyone offer me advice, is it possible to do it yourself (from a girls standpoint)
Old Mar 21, 2003 | 05:21 AM
mike_mck2's Avatar
mike_mck2
Timing Belt?
Have you checked the serpentine belt? Sounds like it's slipping.
Old Mar 21, 2003 | 06:51 AM
tomw's Avatar
tomw
Timing Belt?
I guess the timing belt *could* shriek a little if it was off center on the pulleys, but normally not. It has teeth that make it non-slip, and if it did slip, it would get the cam timing whacko.. and if older, the ignition timing.... So, if it is running fine, the noise is most likely the A/C, power steering, alternator, water pump belt(s)
tom
Old Mar 21, 2003 | 07:03 AM
Bob Ayers's Avatar
Bob Ayers
Timing Belt?
I would say it's the bearing in the idler or tensioner pulleys...
Old Mar 21, 2003 | 08:46 AM
big1's Avatar
big1
Timing Belt?
I had that problem once. Turned out to be the neighbor's cat.
