How much is too much PSI Boost while towing, Stock 06 6.0L/w 4in exhaust. Towing around 12K with 5th whl. 3 slide. Was seeing around 30 to 35psi while towing uphill or flat land.
Too high for stock '06 tuning. Who's tunes are you running?
Stock tunes, was running around 1000 degrees on exhaust temps most of the time, was pulling 5ver from Yuma AZ to Las Vegas then on to home up the back roads from nevada to Seattle area. Did notice while pulling some grades or hills boost psi was getting up there around 30 to 35 a couple of times it was higher, even tried to downshift to another gear to get psi down. After I got home I noticed my oil is super dirty, and coolant is down about 3/4 in from the line of min. on the bottle, is scheduled for an oil change in another 500 miles.
