is there anyway you can take a picture of the back of the panels? I am trying to take the cluster off of my truck, but the wiring is too tight, so even after I removed all the screws, I still can't take the cluster off without pulling too hard on the wires (which I do not want to do). thanks
wow i thought that was an aftermarket dash setup! super nice man did you epoxy the ford center strip onto the bottom? or how did you attach it? im going to pull a part saturday to get some saturn parts for my moms heap and i know there is an old dash unit in a 69 beater out there that im gonna have to try something like that with. thanks for the great insperation
Thanks, I actually used double back tape under it then there are a couple of small post behind the strip that I drilled small holes for them to fit thru the bezel then loctight from behind thru the holes, & the wood is Red Oak treated with spar varnish
