Edge CTS Turbo Timer Settings?
Old Apr 26, 2011 | 10:37 PM
sparkkky's Avatar
sparkkky
Just finnished my Edge CTS install with EGT probe and turbo timer and all went well, the drilling, tapping and wiring I was afraid I might burn up some wiring but it all works great!
EGT's around 500 to 700 Deg. until you romp it then I saw over 1100 but just for a second.
The timer sets at a preset time or by EGT Temps, have seen to set around 370 Deg. is that right?
Old Apr 27, 2011 | 11:37 AM
mixerdrvr's Avatar
mixerdrvr
I would go 350.
Old Apr 27, 2011 | 11:46 AM
Striderwv's Avatar
Striderwv
Others more knowledgeable will chime in, but I would consider a few things:
  • what type of oil (syn vs. dyno)?
  • do you have the updated turbo drain tube?
  • where is yur egt probe?
I'm running syn, have the updated drain tube and my egt probe is pre-turbo. I let my egt cool down to 325 prior to shut down with normal driving. I would go lower if I was working it hard.
Old Apr 27, 2011 | 06:52 PM
sparkkky's Avatar
sparkkky
Always ran Syn, don't know about the tube it got a turbo at 100000, and probes in driver side manifold end.
Took a drive last night and with the cooler temps outside it did not run very long set at 370!
Old Apr 28, 2011 | 10:21 PM
sparkkky's Avatar
sparkkky
Any one else?
Old Apr 29, 2011 | 09:46 AM
TexasA&M's Avatar
TexasA&M
325 seems too low... my truck would have to idle for 30 minutes after running on the highway to get that low. I usually shut mine down at 380, so setting at 370 should be plenty fine.
Old May 2, 2011 | 10:57 AM
airjeff's Avatar
airjeff
How easy is that timer to use? I'm wondering if my wife could figure it out without too much trouble. My other option is get a remote start and use the timer feature.
Old May 2, 2011 | 06:29 PM
sparkkky's Avatar
sparkkky
Its Wife proof unless she goes into the menus!
Old Oct 19, 2011 | 06:19 PM
EXbowtieguy's Avatar
EXbowtieguy
Does the timer work in conjunction with the high idle mod?
Old Oct 19, 2011 | 06:30 PM
1eyedjack's Avatar
1eyedjack
Sparkkkky.. I don't wanna high jack your thread but (lol) I am 95% leaning on buying the edge cts with the juice but am kinda scared to do my own install. on a rate of 1-10, with 10 being the hardest, what would you rate? this would be my 1st mod with my 05 f250.
Old Oct 19, 2011 | 09:07 PM
sparkkky's Avatar
sparkkky
5 I was scared of the tapping the manifold but it went smooth and I am a electrical contractor so that helped.
The timer is preset time or if you have the manifold probe you can pick a shut of Temp. high idle should not matter.
jayhawk714
Feb 12, 2017 04:35 PM
shadetreezj12
Ford Truck Parts for Sale
Mar 28, 2016 04:28 PM
ghott
Jan 28, 2016 03:39 AM
therifleman556
16
Mar 28, 2012 04:59 PM
sparkkky
Apr 20, 2011 09:37 PM
