Aux Trans Cooler Lines
I just bought one for my 73 F100 2wd just for extra insurance against heat. Plus I do alot of slow sight seeing driving and there is alot of stop and go around here.
I am going to still use the factory cooler along with the aftermarket cooler. Im going to have the cooler centered on the front of the rad.
The cooler came with rubber hose but I want to use metal tubing(I already have it). Should I route everything under the rad and come up through the space between core support and bumper or route everything to the passenger side through the existing holes already in core support? The 2nd option keeps everything higher but may cause problems with room if the rad ever needs to come out, id have to remove the extra lines first.
