not starting
Old Apr 24, 2011 | 12:05 PM
ricksmack's Avatar
ricksmack
not starting
01, 7.3 ran great, started it and backed into driveway and shut it off, next morning cranked but wont start, fuel pump working, all fuses seem good, with key on dash all looks normal, oil down in pan quarter in. what happened from running to not starting, dont see smoke at exhaust while cranking,??????????????????????????????????,,,,,,,,,,,ok so i went out brought oil level up in the reserve at top front of motor, i give it a squirt of wd-40 and off it went, why???????????????
Old Apr 24, 2011 | 12:16 PM
JOHN2001's Avatar
JOHN2001
Does your WTS light come on? Do your rpms move while your cranking? Did you check your fuel bowl heater fuse? Could it be your CPS?
Old Apr 24, 2011 | 12:45 PM
JT250's Avatar
JT250
Dealt w this on my buddies truck the other day. Ended up pulling the valve covers and doing the 50 cent mod. The harness' on both sides were about half out. After that the hpop was low so I had to add about a half quart to it. If it is too low you won't get fuel to the injectors. His batteries were also weak so I ended up jumping it w my truck and it started. It would turn over but not fast enough to start.
Old Apr 24, 2011 | 03:35 PM
clintbonnie's Avatar
clintbonnie
If I understand you, you added oil to your HPOP, high pressure oil pump and it started.. If so, it sounds like your check valve in the HPOP is leaking.. Check the level again after it sits all nite.. and report back..
Old Apr 24, 2011 | 03:49 PM
JT250's Avatar
JT250
If i understand it correctly the HPOP is what drives the injectors. Not enough oil in the HPOP res means oil cant get to the injectors so they dont fire. Dont know about the wd 40. The oil was low in my buddys truck because we had cranked on it so long without it starting, it depleted the resevoir.
