carburetor
Old Apr 24, 2011 | 09:13 AM
williampatat's Avatar
williampatat
Question carburetor
i have a 73 ford f series with a 360 2 barrel motrcraft 2100d carb, but do not know where the fuel line coming from the rich/lean adjustment/choke housing goes to, it was un hooked when i took the carb off to rebuild it, can someone please tell me where it connects to, and the backsidew vaccum line as well thank you
Old Apr 24, 2011 | 10:50 AM
4x4 Bart's Avatar
4x4 Bart
The line for the choke comes off the passenger side exhaust manifold. Goes in a small hole on top of the manifold. Many times it rusts and breaks off in the hole. Just use the proper size drill to remove the broken piece in the hole, trim off the end of the line and push it back into the hole.
Old Apr 24, 2011 | 11:01 AM
MattyJessome's Avatar
MattyJessome
It sounds like your talking about the place where the line off of the choke stove goes in. It just carries hot air from your exhaust crossover to your choke ..if you have an electric choke or manual choke you wont need that and it can just be plugged off.
